how do i wire a sensor to my daq having pulse output
Hi all
I am using NI 6229 BNC DAQ and i have a flowmeter which is giving me pulse as output.
In attachment i am sending the datasheet of sensor.
How can i wire it to my daq
Please help?
(3,611 Views)
The Digital Inputs of the 6229 probably want TTL signals (0v = off, 5v = on).  If you provide 10v power to your sensor and use a "divide-by-2" resistor network for its output, you should have the digital signal that you need.  Wire it to one of the Digital Input lines.
Bob Schor
(3,585 Views)
Bob Schor
(3,583 Views)
Hello, can you tell me which the expected output of this sensor is, is it Analog or Digital? This is because depending on that that’s how you wire the signal to the device.
(3,545 Views)
Hi lcgse88 sensor has pulse output. i need to wire it to counter input on my daq. i am not familiar with this kind of input. Thats the reason of my trouble
(3,535 Views)
Duplicate - http://forums.ni.com/t5/LabVIEW/how-to-convert-square-waves-to-a-physical-data/m-p/3149985
There are more than enough threads you have started on the same subject.
(3,526 Views)
Digital or counter? i cannot decide to start
(3,518 Views)
