how do read the data of the excel file line by line to the waveform?
hello:
      i am a beginner.so i hope that  you can give me a small example。the data of the excel  file i
 have given out.
looking for your replys!!!
(3,230 Views)
Did you try a search? This question gets asked at least twice a week.
Option 1: Save it as a text file and use Read From Spreadsheet File.
Option 2: Use ActiveX to read the file using the Excel object model. Do a forum search and you will find lots of examples.
(3,212 Views)
Accepted by topic author 林哥
try this. best of luck
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,196 Views)
