how do we add non-repetitive items to an array
hi all,
iam having the following items in a text file, which are going to be inputted to an array(line by line):
HALL
BALL
PAUL
CALL
HALL
HALL
now what i want is only non-repetitive items should be inserted to the array.In the above example,
HALL
BALL
PAUL
CALL
should only be added to the array and since HALL is repeated in the last two lines, it should not be added.
hope i made myself clear.
santosh
santosh
Message 1 of 12
(3,709 Views)
The OpenG array tools have a remove duplicates VI.
These tools can be installed with VIPM
Ton
My LabVIEW Ideas
Message 2 of 12
(3,708 Views)
hi ton,
is there any other solution.
currently i am using version 7.1 and i have to run the same code on other machine also.
Even if i install VIPM , i think that i have to install the same on other systems where i want to run my application.
santosh.
santosh
Message 3 of 12
(3,706 Views)
Santosh,
in this case I think you'll have to program it yourself. Search the array for the element to add (search 1D-array). If it's already there (index >=0) skip the item, else insert it.
Daniel
Message 4 of 12
(3,700 Views)
Built on how dan has explained
Message 5 of 12
(3,699 Views)
HI DAN AND HI DEV,
the solution provided by devchander is excellent, i could able to convert it into conveninent form and
it is working perfectly, and Dan thank u for providing the algorithm,
cheers guys
santosh.
santosh
Message 6 of 12
(3,693 Views)
Hey thanks!
But I would have been happier if dan alone was given 5 stars, rather than we getting 4 stars each !Smiley Wink
Smiley Very Happy
Message 7 of 12
(3,682 Views)
HI DEV,
I THOUGHT OF GIVING 5 TO BOTH OF U GUYS,BUT SINCE I WAS IN A HURRY
I PRESSED 4 INSTEAD OF 5, ANYWAY RATING IS ONLY STATISTICAL, BUT THE
HELP IS IMMEASURABLE
Smiley Happy
REGARDS,
SANTOSH
santosh
Message 8 of 12
(3,677 Views)
Hey Santosh,
Well said!
Indeed, being able contribute and share knowledge is what matters in this forums!
The stars are just,  Hmm, shall we say 'By-Products'? Smiley Very Happy
All the best to you, Santosh!
Dev
Message 9 of 12
(3,673 Views)
@devchander wrote:
Hey thanks!
Smiley Very Happy
Thanks dev Smiley Happy
But he clicked on the rating 2 times anyway so I think 2 times 5 stars would have been appropriote Smiley Wink
To your amount of stars it won't change much in average, but in mine it still does... but anyway, it's just statistics... help is what counts, you're right santosh.
EDIT: 5 stars from me, dev Smiley Very Happy
Message Edited by dan_u on 09-26-2006 03:39 PM
Message 10 of 12
(3,662 Views)
