how do you change the directory of system exec after it has ran once in the current vi
Hi all,
Attached is the sub vi that i am running in my main application.  I run it twice and change the directory of the file to run.  It appears that after i run this vi that i cant change the directory and it tries to run a file from the incorrect directory.  Does anyone have any advice on how to fix this issue?
-Matt
Message 1 of 9
(4,660 Views)
What OS? The operation of the system exec function can vary with version of Windows.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(4,635 Views)
It's a windows 7 system.
-Matt
Message 3 of 9
(4,594 Views)
You could put the command to run the executable in a batch file that sets the directory first, and then run the batch file.
Mike...
LabVIEW Champion
Message 4 of 9
(4,585 Views)
Could you show me an example of that?
-Matt
Message 5 of 9
(4,574 Views)
A batch file is called the same way as an exe. To create a simple batch file, just type into a text file the commands you would run from the command prompt. Be sure to give the file the file extension "bat".
Mike...
LabVIEW Champion
Message 6 of 9
(4,570 Views)
So you're saying at the end of the first batch file I could just change directories to the next batch file?
-Matt
Message 7 of 9
(4,557 Views)
No, set the directory at the beginning.
Set the directory for the 1st exe, run the executable.
In the second file set the directory for the 2nd exe, run the exe. And so on.
Mike...
LabVIEW Champion
Message 8 of 9
(4,532 Views)
@matt198717 wrote:
Hi all,
I am not sure, if I understand exactly the problem, but do you really need the cmd /c start some_executable.exe. This executes a command prompt window, which executes another command prompt window, where your executable runs.
You can just use cmd /c some_executable.exe some_parameters_if_needed, and you don't need any quotation marks, even if the executable has command line parameters. I you want that the executable runs in particular directory, wire this path to the 'working directory' of System Exec.vi
Message 9 of 9
(4,514 Views)
