how do you create a section in labview using the configuration file vis
I'm trying to create a new section in Labview. All i see is the possibilties to read sections and keys, write keys, delete sections. Is there a way to write a new section in Labview.
Brandon
(4,286 Views)
Accepted by topic author Fulmetalal
When you write to a key, you have to supply a section.  If the section isn't there, then it will be created.  Basically, you can't have a section without any keys.
(4,284 Views)
