how do you detect a right click menu selection on a multicolumn listbox?
Hopefully this is an easy one. I cannot seem to setup my event structure (using LV7.0) to capture the user right clicking on a multicolumn listbox and selecting the cut, copy or paste items.
Mike
(2,754 Views)
I can help you with the first part, at least! You can set up the event case to monitor the "mouse down" event. When this occurs, the Button terminal in the Event Data Node tells you which button they clicked. If the value is 2, then this means they right-clicked. However, I do not believe that there is an event for the choice which they make. You may want to suggest that to NI Support, that it be implemented in a future release?
J.R. Allen
(2,754 Views)
