how do you do math?
titel says it
my specs are
intel i5
240gb phantom ssd
16x blu-ray burner
16g ram
600w power supply
thx
It's is the vigilant who prosper when times are rough ~G. K. Chesterton
Message 1 of 40
(6,359 Views)
Is this a LabVIEW question? If so, in what way?
... And why would it depend on the computer hardware?
(16 grams of RAM? how much is that in GB? How much is 240gb? What does a burner have to do with the math capabilities?)
Message 2 of 40
(6,318 Views)
Hey Altenbach....c'mon man....the "titel" says it all.
2+2=4
8-5=3
Smiley Very Happy
aputman
Message 3 of 40
(6,292 Views)
for labview. to calulate some expressions. like altenbach said. how do I make it into a labview file?
Message 4 of 40
(6,239 Views)
Have you attempted to create any expressions?  Look on the numeric menu and you will see all kinds of nodes for addition, subtraction, etc.  The best way to learn is to experiment.
aputman
Message 5 of 40
(6,221 Views)
The 600W power supply surely makes a difference as well.:-)
Please take one of the many free tutorials or classes. It doesn't seem that you haven't done anything to learn something so basic.
Message 6 of 40
(6,195 Views)
palette.pngwhich one?
Message 7 of 40
(6,157 Views)
You are looking at controls of the front panel. Try the palettes of the block diagram instead.
Message 8 of 40
(6,148 Views)
Right click the block diagram, not the front panel.
aputman
Message 9 of 40
(6,140 Views)
@itesla43 wrote:
which one?
You are looking at the Front Panel... Try pressing "ctrl + e" to bring up the Block Diagram.  This is where you compose the "expressions" to do your "math".  The Front Panel is just to display the results in controls and indicators:
You may find the following helpful:  http://www.ni.com/gettingstarted/labviewbasics/
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 10 of 40
(6,134 Views)
