how do you wire state machine
the examples given by you are very good, take them to a program that stores random numbers in a text file and was useful, you can improve the code, I will try to improve it, attached
Message 11 of 12
(873 Views)
Accepted by topic author dav2010
I did a correction, because the text file is generated an extra row when reading its contents could be seen this problem, you only had to enter the file write vi in the loop, otherwise the information that received the txt was not correct, the appropriate apologies
Message 12 of 12
(853 Views)
