how does digital filter order influnce filtered data , the higher the better?
Seems that higher order filter has better filter effect ofcut-off frequnecy is set to be constant.
So filter order the higher the better?
is there any side effects for higher order? such as phase delay?
(2,666 Views)
fenny,
The main effect of a higher filter order is that the roll-off is much quicker (i.e., there are fewer frequencies between the pass band and the stop band). Depending on the type of filter that you use, there may be more phase delay with higher orders. Some filters are designed for phase delay (I think elliptical and Chebyshev are phase delay filters), but some filters will not give anymore phase delay with higher orders (e.g. a Butterworth filter). But there aren't really any "side effects" to having higher orders other than possibly longer processing times. I hope this answers your questions!
Tyler S
(2,647 Views)
for my signal processing, phase delay is unwanted "side effect"!
(2,645 Views)
