how i can Load multiple arrays automatically into a array?
Cordialement.
(4,075 Views)
hi sarah,
please be a little more specific what you want to do.
what are the inputs, what is the expected output, what does automatically mean for you?
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(4,058 Views)
Hi JWSCS,
I want to concatenate many arrays in a dynamic way, Add columns to infinity in multicolumn list for example.
Thank you .
(4,053 Views)
the problem is with the dynamic, i suppose you mean while the program is running, on specific occasion, your main-array will be extended.
there are multiple ways of doing that.
1) if you are in a loop, use shift registers to hold your main-array
2) use a global variable (global, functional global variable, action engine)
3) since you mention a 'multicolumn listbox', you could get the value append new stuff and set the value of the listbox to the new array (try to get a property node from your listbox, and use the value property)
(4,046 Views)
Thank you ,
But i d'ont find it can u give me a example please.
thank you .
(4,041 Views)
Accepted by topic author Sarah_LAB
sorry, the property was named "ItemNames"
very simple example:
(4,030 Views)
