how i can have comunication between ABB Digitric 500 and LabView 6.1
Digitric 500 use modbus protocol to interchange information with the PC.
(3,237 Views)
If your device supports Modbus, then you can use Industrial Automation OPC Server to interchange information between the device and LabVIEW. Here's the links you might want to check.
http://sine.ni.com/apps/we/nioc.vp?cid=11127〈=US
http://www.ni.com/opc/opcservers.htm
Remzi A.
(3,237 Views)
