how i can't change anything in the vi who is using activex invoke nodes for excel97 when i have a newer version of excel
as an example:
the ActiveX example has executed at LV5.1 Write Table to XL.vi.
The following has arisen in the context of it.
This is Vi as long as nothing is changed at the diagram executable.
Only a constant is put in the diagram this isn't Vi any more executable.
The error message says from that one of the method knots doesn't work.
Uses gives it to Excel 2003. to this can notes or tricks like the problem be avoided.
Have a number of tools calls the Excel it comes to the error messages listed above to have about activeX and to work without problems under Excel97 and to be allowed to not be changed under the current version of Excel any more otherwise there.
(2,413 Views)
No, you can't select different Excel version at runtime in labview. Microsoft changed some properties and methods during each version upgrade. Sometimes they are not backward compatible, labview can't dectect the difference because the properties and methods are hard-wired during development time. You'll need to relink these methods and properties and recompile the code.
-Joe
(2,408 Views)
