how i can to drag and drop a file in my applciation?
how i can to drag and drop a file into the all window of my application and read this file of corse,??
Please i need your help ,
Thank youu .
Message 1 of 16
(5,173 Views)
You can drop a file into the path control and it will populate the path of the file.  If you need to read the file as soon as that happens, use an Event Structure and the path control's Value Change event.
Message 2 of 16
(5,142 Views)
Create a Value Change event in an event structure for the path control.
(Note, a Select Function with True and False inputs is a Rube Goldberg)
Message 3 of 16
(5,139 Views)
I dont want to  drop file into the path control i want to drop it anywhere in my window ???
Message 4 of 16
(5,135 Views)
that is not really possible.
http://zone.ni.com/reference/en-XX/help/371361N-01/lvhowto/dragging_and_dropping_vis/
a hackish possibility would be to make a path-control fit the whole pane, and put other controls/indicators in front.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 5 of 16
(5,122 Views)
Okey, But i can to drop it on the graph or table ... ?
Message 6 of 16
(5,113 Views)
If you place a transparent path control over it, but then you can't interact with the graph anymore.
Rolf Kalbermatter  My Blog
Message 7 of 16
(5,110 Views)
thank you ,
Message 8 of 16
(5,101 Views)
i Can't drop a text file(myfile.txt) in String indicator and show it how i can do it please  ?
Message 9 of 16
(5,074 Views)
Only the path control allows to drag a file from the explorer into it! Do the same as with the graph, place a transparent path control over it!
Message 10 of 16
(5,067 Views)
