how i convert boolean to string ?
which function do it ?
thanks 🙂
Message 1 of 10
(51,955 Views)
There is no standard way of converting a boolean to a string, so there is no function to do this (a "True" boolean string can be "1", "-1", "Yes", "T", "True", etc.). You can do this by using a case structure or the Select function from the comparison palette (insert a boolean and output whichever string you want). You can convert it to a variant or to a number and then to a string or you can type cast it directly to a string. In short, it depends on what string you want, but the easiest way is by using the Select function.
This is really a rather basic question. To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
Message 2 of 10
(51,946 Views)
If you want true/false output use attached vi
LV 2011, Win7
Message 3 of 10
(51,947 Views)
Use "Format into string"
LV 2011, Win7
Message 4 of 10
(51,937 Views)
This will send you "TRUE" or "FALSE" strings ... if you need to convert it to "1" or "0" strings (or any other strings you want) then use a simple case structure.
Message 5 of 10
(39,275 Views)
have a look at this
Amit
CLAD
Message 6 of 10
(39,250 Views)
Format into string will satisfy you to get string value of a Boolean (TRUE /FALSE)------
Provide format string as %s
input 1 as T /F (*Boolean)
output will be (TRUE/FALSE)
Message 7 of 10
(39,236 Views)
Continuation of previous post
If the expected value is (0/1) for (False /True)
then provide format string as %d
Message 8 of 10
(39,216 Views)
@amitwadje wrote:
have a look at this
!0.pngavoids those dreaded BD ConstantsSmiley Wink
Message 9 of 10
(39,128 Views)
Phew.  Good thing he has an answer now after agonizing through 9 years of slience on this thread.
Now, if only there were about 5 different ways to do this easier.
Message 10 of 10
(39,014 Views)
