how make delay between two signals?
 After reading two signals from input by use of DAQ assistant, I want to make some delay between 1st and 2nd signal,would you please tell me how I can do it ?!
thanks
(3,605 Views)
Please explain on more detail.  Do you want to add an artificial delay between the measurements?  Are you reading one data point, multiple points, waveform?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,593 Views)
I guess you could use the Wait (ms) vi from Programming -> Timing and specify the number of milliseconds you want to wait for.
You could put it so that it waits before reading the second signal.
But again, you should be a little more specific
(3,588 Views)
Infact I have two input signals which are waveform, and first  read both of them and determine their amplitude,frequency and phase, then after calculation the phase difference between these signals I have make  time delay between signals to see the effect of that on my circuit,(some kind of feedback; because by changing the phase difference between these two signals respond of my circuit is changing,that's why I want to implement time delay) .
 hope that my explenation is understandable and sorry if my english is nt good 🙂
thanks for reply and help
(3,572 Views)
So are you outputting the new waveforms through an AO as a feedback?
(3,557 Views)
as far as I think I can not put a delay on original signal before putting that in output, So I output the new waveform 😞
do you have any idea about outputting the original signal with delay?! if so, it would be great
(3,555 Views)
