how make geranator frequency 15-25kHz with also change tension level 0-10V ?
hey
i am new here and on labview - i would like your help, please
I have made genarator with daqmx blocs but i don't knew how to controle these blocs in time relle with very fast refresh on the desktop and on the analog output? one whot can i do are set frequency and amplitude without modification.
thanks for your help
Marek
(2,664 Views)
What is the hardware that you are using?If english is not your first language then post in your native language also.
(2,642 Views)
hey
I have written in in Polish, also adds tranlation in English.
to jest moj jezyk ojczysty
Mam pytanie odnosnie szeregu blokow daqmx uzywanych w przykladach
biblioteki. A mianowicie czy jest mozliwe sterowanie tymi blokami w czasie rzeczywistym
z bardzo duza szybkoscia odswierzania? do generowania sygnalu moge ustawic
wartosci czestotliwosci i napiecia bez mozliwosci modyfikacji w czasie
terazniejszym. probowalem z petlami for i while dla roznych blokow bez skutku - caly
czas dzila wolno bez mozliwosci modyfikacji albo program labview sie wylacza
gdy wstawie petle na niektorych blokach. w zalaczniku zamiescilem generator
nad ktorym pracuje. musze w nim zrobic generator napiecia w zakresie 0-10V
rownoczesnie z automatyczna zmiana czestlotliwosci 15k-25kHz.
I have a question about a series of lock used in the examples DAQmx
library. Namely, whether it is possible to control these blocks in real time
with a very high speed refresh? I signal to generate a set
the frequency and voltage without the possibility of modifications during the
present. I tried with for and while loops for different blocks of no avail - the whole
time today may be no possibility of modification or the LabVIEW program itself off
When you insert loops on some blocks. why all Daqmx blocs are low times changed. I weit 5 (s) for set up and for see samothin on output. I need it to do the generator voltage in the range 0-10V
simultaneously with the automatic change frequency 15k-25kHz
Thanks for your help
Marek
(2,623 Views)
