how many items can has one VI?
Thanks Norbert
I was starting from a blank VI but I using controls from the standard palettes and  DSC module. But then I deleted all controls DSC module.
And I will try to run this VI today an another machines.
I don't use custom typedef .
How can I copy my VI to another new empty VI ?
Because in new VI I don't observe this error.
respect
Isksnder
Message 21 of 23
(654 Views)
Iskander,
in order to copy the content from one VI to another, i suggest to switch to block diagram, press Ctrl + A (select all) and then Ctrl + C (copy selection).  In the new VIs block diagram press Ctrl + V (insert copy).
This will not copy elements from the front panel which do not show up in the block diagram (like free labels).
It will be interesting if the copied content will create the issue in a new VI as well or not....
Norbert
Norbert
Expert: Geometry
Message 22 of 23
(650 Views)
thanks
I did so.
I copied the FP or block diagram.
I can't copy FP with block diagram.
Message 23 of 23
(644 Views)
