how reactivate closed webbroser
google translation: Portuguese to English
I'm using the event newwindow2 it works perfectly.
The problem takes place in windows that close with button to submit. the webroser closes and does not work again in the next event newwindow2.
The attached VI simulates the closing of the webbrowser
Is there any solution to reactivate the webbrowser?
(2,570 Views)
Can someone help me how to proceed in this situation where the window closes?
(2,425 Views)
It is strange. The container is acting like a hidden control. What are you trying to acomplish? Are you trying to unload the ActiveX container, hide it, something else?
LabVIEW 2012
(2,416 Views)
not want to hide the ActiveX container, this is the process fechameto the page by pressing a button submit. However, I need to activate it again for the next event newwindow2.
The VI attached only simulates the closing of the ActiveX container, as the submit button the web page does
(2,405 Views)
