how read xml and save ita content in .txt format
Is it possible to read a xml file and save it in .txt format. Please let me know if there is a way to do that.
Ankit G
(2,962 Views)
(2,961 Views)
I tried it, but Its not saving the content of xml file.
Ankit G
(2,954 Views)
What does it do then ?
What do you expect it to do ?
You need to explain in more details what you what to do.
(2,941 Views)
Accepted by AnkitG
That read function is only for xml files written using the LabVIEW schema so if you have something else, you would need the functions on the xml parser palette.
(2,934 Views)
Thanks, My xml file is not written using the Labview schema, I will try to use parser palatte.
(2,930 Views)
