how should I init a pci-6527 in visual basic and labview
I need to init a pci-6527 in labview and visual basic, in visual basic I open the component cwdaq.ocx and add it. Then I select CWDIO and when init the pci-6527, it not gives me the ports, it wich has to give me a valor diferent of Zero, it wich is 6.
Thanks for your attention.
(2,562 Views)
Hi hertcube,
I will give you the link where you can find some examples using the PCI 6527 with LabVIEW and Visual Basic:
http://search.ni.com/nisearch/main/p/sn/catnav:ex/q/6527
Specifically check these two:
Digital Output in NI-DAQmx using Visual Basic 6.0
NI-DAQmx: Check the Status of Outports on a PCI-6527
I hope that works for you.  Have a nice day.
P.S. También puedes hacer preguntas en los foros en español.
Pablo Bernal | NI Mexico
(2,514 Views)
