how to Store attributes of an object temporarily till my vi is running?
hi,
im having a class wherein i have two vi's with some functionality. Now if i create an instance (object) of this class,
 i want to set some attributes to it and i would like to call these set attributes from a same and/or a different vi but my
ultimte aim is that i should store it in some container from where i can use it if necessary. i don want this to be stored in a file.
Cos once the vi stops running i don want this data to be available anymore. I hope u got my ques clearly now.
Regards
Jayaraman
(2,654 Views)
You could use shared variables. Or if the VI's are in the same project you could store the info in a queue.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,634 Views)
Do a search on "Action Engine" within this forum.  A sub-section of Action Engines is something called a "Functional Global Variable".
You can also do a search on that.  Functional Global Variables are VERY different from Globals or Shared Variables.  They are often used as a container to store values and allow to share among VI's.  It only retains the last value written to it (unless you modify the structure but I won't get into that).
RayR
(2,628 Views)
Duplicated post, see here
- Cheers, Ed
(2,626 Views)
