how to access all the keys of keyboard in labview
i want to access the alphabets of the keyboard in my labview program
(2,666 Views)
I'm not quite clear on what you want to do here. Please explain in more detail.
(2,666 Views)
You will find an example on the Example Program Database:
http://ae.natinst.com/devzone/explprog.nsf/41ee12ddba6c766a8625684700691463/832b604cb371a54686256540004f7b3c?OpenDocument
and I have also attached it to this response. This example uses the keyboard VIs to intercept keystrokes and then display those keys in a string indicator when the What Have I Typed? button is pressed. The example was created in LabVIEW 4.1.1, but you will be able to run it with later versions, too.
Zvezdana S.
(2,666 Views)
