how to access pci 9054 with labview
Iam using pci9054 for communication,how can i configure pci 9054 with labview.
(3,651 Views)
Hi,Jisnu
I strongly reccomend you to follow the link given below and can understand the concepts throughly.
http://read.pudn.com/downloads83/doc/320499/pci9054.pdf
Hope.....this might helpSmiley Happy
Thanks as kudos only:)
(3,640 Views)
thanks for your reply.
I was looking for sample code where the PCI9054 can be detected using labview and able to communicate with the PCI slot
(3,629 Views)
I doubt very much that you're going to find sample LabVIEW code for this, since you are asking for a very rare operation. Your best bet is to look for sample code written in a text-based language, like C. There may even be a library available. If there is, you should be able to call it from LabVIEW, although depending on the complexity of the functions and/or datatypes, you may need to write a wrapper DLL to interface between LabVIEW and that shared library.
Overall, you're not asking for something simple. How much programming experience do you have? You're going to need it.
(3,621 Views)
Accepted by topic author jisnu
Thanks for your reply,
i have 6 months experience in programming.
(3,609 Views)
