how to acquire counter data in labview
Hi for one of my applications i need to acquire counter data so to test that i have generated the counter using labview and i want to acquire the counter. i have attached the complete vi including counter generation(upper block) and acquiring(below block).the problem is that i am not getting samples while acquiring.So can anybody help me out..
with regards
Prashant Achari
(4,047 Views)
Not really going to help if you are going to post multiple times. Stick to this thread.
(4,028 Views)
(4,022 Views)
Sorry for that...i am new for this site..
Will you please tell me the solution for the vi i have sent....
(4,021 Views)
Did you check the example? Also i will recommend you to change your user name (Cell number) to avoid receiving craps of spams..
(3,998 Views)
