It's a little difficult to give a straight answer to your question.
One vi has only one front panel, if you want to be able to change your user interface, you can do it in several ways:
You can use tabs, change properties of objects, like visible/enabled, ...
You can also put other vi's on top of your main vi changing parts of the user interface.
Hope this gets you started,
Paulo
