how to add 15 bit can crc calculation to labview polynom is x15 + x14 + x10 + x8 + x7 + x4 + x3 + 1 .
how to add can crc calculation to labview polynom is x15 + x14 + x10 + x8 + x7 + x4 + x3 + 1
for 15 bit calulation
thanks for any assistance
(4,055 Views)
Hi there,
Here you can find the explanation of how the CRC calculation is done (see page 15). Now, if you are planing to do this with NI hardware/software it does not make sense since the calculation it is already taken care by the driver. In case you want to do this on your own using digital lines be careful with impedances and any other electrical consideration.
I hope this helps
Alejandro C. | National Instruments
(4,020 Views)
the driver you are refering to, does NI have a Can driver that I missed?
(4,012 Views)
NI-CAN & NI-XNET. Choosing one or the other depends on the hardware to be use.
(4,005 Views)
