how to add HBM MGCplus(third oarty) in labview
How to install or add this DAQ driver plugin which i found http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E959D659CE034080020E748...
pls tell me step by step procedure..
once its done, where i can find this daq in ma palette?
thanx in advance
Every Expert was once a Beginner!!
Message 1 of 10
(4,721 Views)
Hi Proing,
your link is broken. Please provide a correct one...
Message 2 of 10
(4,713 Views)
Message 3 of 10
(4,710 Views)
Hi Proing,
when you go to the driver's website you will find a link describing how to install them? Did you notice that link and did you read the help page?
Message 4 of 10
(4,706 Views)
Hi GerdW!!
Thanq very much..
Once I installed this, is that possible to use just like NI DAQ or shud I program it with VISA?
Message 5 of 10
(4,704 Views)
Accepted by topic author PROing
Hi Proing,
I don't want to be picky, but why did you mark your link as solution?
Once you installed the driver you should read the "ReadMeE files included in the package... Then you should play with the examples to understand how the driver works. And, as noted on the driver's page you will use VISA...
Message 6 of 10
(4,701 Views)
tat was mistake, and is there any possibility of undo this?
Message 7 of 10
(4,699 Views)
Yes, probably in the options menu of the message!?
Message 8 of 10
(4,697 Views)
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=2114
this is not certified by NI, what does tat mean?
this driver doesnt work in labview?
thanx in advance
Message 9 of 10
(4,686 Views)
Hi Proing,
it's not programmed by NI nor does NI provide support for this software.
But nevertheless it is written in LabVIEW and will work with LabVIEW!
Message 10 of 10
(4,684 Views)
