how to add a FRAME to several indicator or control
Anyone can tell me how to add a frame to several indicator or control on the front panel,just like the "frame" control in Visual basic.thanks a lot!
(4,279 Views)
On the controls palette for the front panel, there should be a sub palette called Decorations. This contains many frames, borders and lines to use on the front panel.
See the attached image taken from LabVIEW 7.0
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,279 Views)
If a frame in VB is what I remember it to be, then look at the Decorations palette. There is a flat frame, recessed frame, raised frame, and all sorts of other things. There is also a frame on the Dialog Controls palette.
(4,279 Views)
thanks a lot for your help,but when i try to add control in the frame,it was covered and can not show,could you please tell how to make it shown?
(4,279 Views)
Got it,your help is greatly appreciated!
(4,279 Views)
Sounds like you found it, but for anyone looking at this thread in the future, just select the decoration and use the Reorder menu (drop down menu with two arrows forming a circle near the top of the screen) to send it to the back.
Ryan K.
(4,279 Views)
