how to add a space&comma every 2 characters in a string?
need to turn this string: 60F87E00, into 60, F8, 7E, 00
Message 1 of 9
(3,053 Views)
Take a look at the functions available in the string palette and give it a try.  Maybe String Subset and Concatenate in a loop would be a good start???
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 9
(3,031 Views)
Somebody here can probably reduce this to the size of a postage stamp.
EDIT: You can use Array to Spreadsheet to add commas, spaces etc. You should be able to figure it out.
Message 3 of 9
(3,004 Views)
Are you even sure this is a string?  It looks suspiciously like a 32-bit integer and those are the values of the bytes.
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(2,998 Views)
Message 5 of 9
(2,994 Views)
@mcduff wrote:
You ruin all the fun.  😄
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(2,989 Views)
How's this:
Message 7 of 9
(2,944 Views)
So maybe each byte represents 8 status bits?
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(2,941 Views)
This is better:
Message 9 of 9
(2,940 Views)
