how to add additional minute time
hi,
      how to add additional minute in time stamp.i will try to add but it will  come constantly 5hour 1minute only.
(3,388 Views)
Hi Hans,
two problems:
- overly complicated way to add a value to a timestamp: when you want to calculate with timestamps you should actually USE timestamps!
- wrong format code for the FormatDateTimeString function! (Read the help!)
(When you just want to display the timestamp you could use a timestamp indicator and change it's formatting…)
(3,370 Views)
hi,
     i will given externally hour,minute,second.
(3,360 Views)
Ok, no problem… 🙂
(3,350 Views)
Check this:
http://www.notatamelion.com/2015/04/27/pay-attention-to-units/
Doing math on time is a specific example I use.
Mike ..
Certified LabVIEW Architect
LabVIEW Champion
(3,287 Views)
