how to add context help text to a property node of an XControl?
Hi
anyone knows how to add description for a property node of an XControl which should appear in the context help window of LV?
In case of a method, the description of the method VI appears on the context help. But not for property nodeSmiley Sad
(3,539 Views)
Accepted by topic author Vsh
Hi Vsh,
You can set the property context help by right-clicking the xcontrol in your Project Explorer, selecting Properties,  selecting the "Item Settings" category and clicking on the Property that you wish to write context help for.  You will see a box titled "Description" on the right;  this is where the context help is defined.
Let me know if you have trouble finding this.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,516 Views)
ok.. Thanks
Thats very good. Works fine.
Thanks again
(3,504 Views)
Did they move this in 2011?  It is not where the description above says it should be.  Please help.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(2,837 Views)
