how to add point in every thousand, million, billion ?
hi  all, i want to ask about how to add point in numeric indicator so it will be show 20.000.000 ?
thanks~
(3,365 Views)
Hi Rhiesnand,
format your number into a string and insert as many points as you need…
Or read this LabVIEW Idea Exchange entry (and note the link to the other idea)!
(3,355 Views)
Hi GerdW,
sorry i didnt get it, what do you mean insert as many points as you need… ?
can you give me the picture ? so it will be easily to understand ? simple code will be better
thanks
(3,337 Views)
Hi rhiesnand,
you asked for "insertion of points" in your number and I told you to insert points after you converted your numeric to a string…
Did you read the linked documents?
(3,330 Views)
oh sorry, i think you have 2 solution. okay thank you very much !
(3,323 Views)
