how to address an cell in a boolean array
Hello
I am intersted in addessing a certain cell in a boolean array.
Suppose I have a boolean array called bArr which is of length 10 and contains  values  of { T,T,F,F,F,F,T,F,T,F }
and I want to send to an "AND" gate bArr[0] together with  "TRUE" constant.
How do I address the cell bArr[0] or any other cell in bArr ???
Lavi
P.S: I am using LabVIEW 8.0
(3,024 Views)
Based on your previous question regarding Matlab, you need to spend some time reading and doing some of the LabVIEW tutorials. Your question is so fundamental that you need to take the time to do that yourself so you can be more productive. Hint: "Index Array".
(3,017 Views)
Use the Index Array function from the Array pallette.
- Partha ( CLD until Oct 2027 🙂 )
(3,006 Views)
Thanks for the hint
Lavi
(2,997 Views)
Hi Lavi,
You could ve easily given me 5 stars atleast ! Smiley Very Happy
(2,986 Views)
