how to adjust light channel of phototransistor/photodiode in multisim10
Hi all,
         I m working in multisim 10 .. and i had to use phototransistor /photodiode in one of my ckt for which we have to set light channel values  as said in HELP  bt i unable to do so....b'coz in help i read that there is light channel option in value tab of properties.......bt i couldn't find so.........somebody plzzz help........i shall b highly grateful...........
(6,446 Views)
It seems you accidentally posted this in the LabVIEW forum. You might want to post this in the multisim board.
(6,441 Views)
In the Multisim component database go to the Misc Group and select Misc_virtual Family, you should find a generic optocoupler.  The input is voltage and it suppose to represent light.  I googled "Photodiode SPICE" and I found a model for you, agian the apply voltage to the P pin represent light.  With this model you should be able to create your own component and if you don't know how this is done, please refer to the following online tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/3173
 .SUBCKT MLED96 A C P
* A = Anode
* C = Cathode
* P = (light)Power as output voltage in Watts
* Diode forward, reverse leakage and breakdown, and capacitance
characteristics
DLED A VC MLED96
.MODEL MLED96 D
+ IS=10.000E-21
+ N=1.5219
+ RS=1.7433
+ CJO=50.000E-12
+ M=.3333
+ VJ=.75
+ ISR=100.00E-12
+ BV=5.3573
+ IBV=10
+ TT=5.0000E-9
* Leakage resistance
Rleak A VC 40Meg
* Input resistance
Rin P 0 1G
* Power output (as a voltage) - fit to total power output vs. forward
current curve.
ELED P 0 TABLE
{pwr(I(VLED),1.170105501)*EXP(-2.114426964-4.065819492*I(VLED))} (0,0) (1,1)
VLED VC C
.ends
Tien P.
(6,317 Views)
