how to append path and import VIs from a folder, and exclude some?
Hi, I am using Build path and Open VI reference to open all of the VIs and import their names in a multi column list box, but there are only 2 files in the same project, that I want to exclude, otherwise I get an error when trying to run. How can I programatically do that?
Seli6272@D
(489 Views)
Hi Seli,
You need to filter the array of filenames to exclude those unneeded VIs…
As we don't know the VI filenames we cannot help you with implementing your filter algorithm!
(Why are those 2 VIs in the same folder when you don't want to handle them the same way as all other VIs???)
(460 Views)
