how to arrange vi's
hi,
i have created driver for my monochromator.this are four vi's with one dll file.
one is to set wavelength, other to set grating,scan rate,and wavelength scan.
my question is ,can i arrange alll this vi's as one vi's.so next time i didnt have to open the vi separately to change parameter of monchromator. that means there would be only one front panel to control all the parameter like,wavelength ,grating etc. i am using labview 8 .if it is possible ,how can i do that.
thanks
(2,960 Views)
Hi josan
I'm not sure if I correctly anderstood, but I assume that you have four different vis and each vi calls this dll to set different parameters.
So if you want to just open one vi - create one vi where the four vis you developed are used as subvis. This gives you the possibility to have one gui to set all parameters.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,953 Views)
hi,
ya exactly what u say i want to do.
so how can i make a one vi and use other as subvi. is there any example of this.
i appreciate
thanks
(2,940 Views)
A great place to start looking for information on using subVIs is the help. We have a complete indexed version online, or you can always click F1 from LabVIEW to open a local copy.
You can find information about calling subVIs here and creating subVIs here.
There's also a link from the New to LabVIEW section of the Getting Started window in LabVIEW called Getting Started with LabVIEW. Just click there for lots of good resources. Hope this helps!
Jarrod S.
(2,914 Views)
