how to attach a picture to a reply post
How do i attach a picture to a post i reply., i.e. within the posts text area directly so it will be visible always and not through the 'add attachments' option.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,363 Views)
Accepted by topic author JK1
Here is a little How-To:
  1. Upload the image with the 'Add Attachment function'
  2. Save the message
  3. Return to the message
  4. Right click on the image URL, select 'Copy URL' (or similar function)
  5. Click on the 'Options' function on the right hand upper side of the message window
  6. Click on 'Edit message
  7. Place the cursor on the place you want to import the image
  8. Click the  'Insert Image' function
  9. Paste the URL you copied to the clipboard
  10. Et voilá the image is 'inline'
Ton
My LabVIEW Ideas
(3,352 Views)
It worked!!!
Thanks a lot.
With regards,
JK
(3,349 Views)
