how to automatically turn off leds after 1 minute/button press
I need help on how to turn off my LEDs 1 minute after my program starts or when the stop button is pressed.. I tried putting a while loop over the LEDs but it doesn't work.. Also the score automatically resets after 1 minute.. how do I maintain the score while turning off the LEDs? thanks.
(3,929 Views)
Find the example programme for ur need.Hopes this helps.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,918 Views)
I added a ms tick counter to replace the timeout function. Take a look.
Tim
GHSP
(3,891 Views)
 Hi aeastet,
can you please convert your file to an earlier version coz I'm using LABView 8.5 and I cant open it?? thanks.
(3,863 Views)
VI in 8.5
Balaji PK (CLA)
(3,847 Views)
