how to blink Boolean indicator i given color based
       how to blink Boolean indicator i given color based.here i attached my program. i will given green and blue but when i run this it will blink Red and blue and red and green.i want to blink blue and green.
(6,216 Views)
Hi hans,
the blinking color is defined in the LabVIEW options. Only there…
When you want to change colors easily you should use a colorbox indicator!
(6,203 Views)
Accepted by topic author GokulGKM
Hi madhanskm,
Here's what I've come up with. The value of the boolean changes from true to false with every iteration of the loop. You can change the timing of the loop to change the rate at which the led blinks.
Blinking led
Hope it helps,
goffauxs
(6,200 Views)
That's what I had in mind:
(No need to set a property to the very same value each iteration!)
(6,196 Views)
Well that fairly well sucks!  Just setting the blinking property is a whole lot less obtrusive than having to programmatically toggle the color.  Now I know why my yellow indicator doesn't appear to blink. Smiley Frustrated
Jim
LV 2020
(5,962 Views)
GerdW, you say the blink color is defined in Labview options, but some blinking are in red, some in yellow?
The example is blinking in red, when i make a Square Led for example it is blinking in yellow, what is the difference?
Francly all my booleans are blinking in yellow, how do you get red?
(5,785 Views)
goffauxs
I tried your solution, with a loop time of 500ms, and it blinks in three colors! Green, blue and red.
Ola
(5,781 Views)
