how to build an exe with option ?
 soryy everybody, my english is pool
i have a  question
if I have a  vi  with two inputs 'a' and 'b',one output 'c' ,c=a+b
how can i build an exe named 'add.exe',that can output 17 with command 'add.exe -8 -9" ?
(3,105 Views)
      Which version of labVIEW you are using? If it is 8.0 or higher version select Project from the tool bar, New Project>Add Save the project you have created. Right click on Build applications>New>Application(EXE). You can find this only if you have installed application builder or PDS. Hope this helps you.
(3,101 Views)
hi,
i can build exe,but when i open CMD,input 'add.exe -8-9' and press ENTER,there is no anwser
WHY?
(3,096 Views)
      I am not gettin you. What does this CMD means? Explain the problem you are facing in brief .Pls post your VI here.
(3,088 Views)
Here's a KB article.  It says "You can reference the arguments in the block diagram by using the Application:Command Line Arguments selection in a property node."
Here's how I did it this morning.
Have a great week.
Jim
Jim
(3,071 Views)
