how to caculate coherence function correctly
I am trying to calculate coherence function of two input signals. Both of the signals contain a sine wave and  ambient noisy. The two sine waves have the same frequence and different magnitude while the two ambient noisy is non-correlation. The input signals are from a digiter which its output is 1D-array. I have tried many method but the results are always  1 at all frequence. Is  the problem  the same as knowledgeBase document: [broken link removed; article no longer available]) but I sitll don't know how to do it .
can anybody give some hints or idea ?Thanks very much!
(3,217 Views)
 Thank you for posting the doubt.
I am also searching the detail.
What I have done so far is given in one of my papers,
attached for your convenience .
You can go though gradulally.
After the publication I am working out what it explains
Take a sin wave of say 50 c/s for some duration and magnitude .
Take another  50 c/s sin wave of same duration but of higher magnitude .
The coherence is 1.
Take another sin wave of higher frequency say 100 c/s or non harmonic frequency  of 80c/s .
the coherence is 1.
Take two sin wave of same frequency , same lenth ,same magnitude but displaced with refence to  time for a fraction.The coherence is not uniformly 1.
It is stated that it represents Spectral Pwer density.
I am trying to understand myself .Once I understand I will get back to you
In the meanwhile if you find any thing further please let me know.
Dr. B P Singh
9985306503
(2,927 Views)
Please see one of my papers,
Further in next mail
BPSingh
9985306503
(2,927 Views)
