how to calculate de area of a waveform in LabView with the oscilloscope Tektronix TDS380
I have a question about a mathematical algorithm. I am using the Tektronix oscilloscope model TDS 380 and since now I have been taking measurements peak to peak, putting in the labview program MEASU: MEAS1: VAL?
I am interested in calculating the area of the waveform, and the instruction manual for the Tektronix TDS 8000 found the command MEASU: MEAS1: TYPE AREA. This command is not in the manual for the model TDS 300 and therefore do not know if you can apply FOR IT. When I insert it I get the error code -1073807339.
My question is: would it be possible to calculate the area with my oscilloscope TDS380 somehow and with LabView? Is it possible to apply the algorithm or can be done differently?
Message 1 of 1
(2,369 Views)
