how to call a Component Object Model (COM) object
Thanks a bunch,
I would give that a shot, but if I am going into the underbush, Thanks for the bush KnifeSmiley Very Happy
Message 11 of 16
(2,225 Views)
Hello again:
Brian I thought I don't have to bug you again but I was wrong
I can't register the type library
http://digital.ni.com/public.nsf/allkb/4F811A9B23F1D46E862566F700615B7A?OpenDocument
didn't work. I tried to google up some methods and that doesn't work either. and then I tried hitting straight with Call Library Function and the whole labview shuts on me.Smiley Sad
Message 12 of 16
(2,221 Views)
Well, you don't need to register the typelib - you can simply browse to it from the ActiveX selection dialog. The COM component itself (the shell) is already registered. I dropped an invoke node and selected the interface and was able to see the methods.
DON'T use Call Library node - use the ActiveX palette only for these things. If you need to call one of the Shell Win32 methods, however, you do use the Call Library Node.
Message 13 of 16
(2,218 Views)
Hello Brian,
It's been a while but I have been away, so I might be much to ask. But here it is:
I am just wondering if you could tell me which reference I should use for the invoke node that I call these by?
thanks
Jimmy
Message 14 of 16
(2,179 Views)
I'm not sure what you are asking. You need to call the Automation Open node on the shell CoClass that you want, and then you can pass that refnum into the invoke node. ??? What exactly are you looking for?
Message 15 of 16
(2,170 Views)
Oh I am actually trying to get this to work.
You see if this works Brian I can get rid of the extra tab or any tab that I don't need.
I don't really understand that shell co class part
Message 16 of 16
(2,164 Views)
