how to call single vi in multiple windows
i have one single graph accessing data through global variable in a file grpah.vi.  Graph runs in a while loop.
In my main vi, i have 4 sub panels. pressing respective buttons should display graphs in respective sub panels using graph.vi . I am using event structures for button clicks.
Can some one guide me to implement the program.
Ranjith
Message 1 of 8
(4,303 Views)
Hi Ranjith,
you can one vi only show ones in a subpanel. Use the invoke node to add and remove the sub vi to/from your sub panels. Before you add it to a new sub panel you have to remove it from the other one. Use a shiftregister to store where it was last inserted.
Hope it helps.
Mike
Message 2 of 8
(4,302 Views)
Hi Mike,
Thanks for the quick reply.
Okay. let me know weather i can do defferently.
I have one button "Open in new window" in my main vi. pressing that i want to call graph.vi in multiple windows based on number of times he pressess the button.
Again graps run in while loop accessing global data.
How can do this?
Ranjth
Message 3 of 8
(4,299 Views)
Hi Ranjth,
if you need your graph.vi multiple times, i recommend to create a vi template. If you use it later, you will get a new instance for each call. If you make it in this way, then you can show it at the same time in all sub panels.
Mike
Message 4 of 8
(4,297 Views)
Mike,
I am new to LabView. can you please tell me what is vi template? If you can explain more it would be really helpful to me.
Thank you
Ranjith
Message 5 of 8
(4,292 Views)
Hi Ranjith,
attached you willl find an example.
Hope it helps.
Mike
Message 6 of 8
(4,278 Views)
Hi Mike,
This helps me greatly. Thanx.
I need to provide a option to display graph.vi in multiple windows clicking single button multiple times from main window. . Graph collect the data from global variable. i tried this, but some times 2nd new window opens on 1st  window or i get blank 2nd new window. Can you help me !!
Ranjith.
Message 7 of 8
(4,273 Views)
Hey Ranjith,
I found an example called Occurences2.zip from Re: Community Nugget 1/29/2007. It should help you understand how to call a predetermined amount of VIs.
The only thing is that you'll have to specify a predetermined number of VIs beforehand.
Hopefully this helps!!
Aashish M
CEO
TransferFi
www.transferfi.com
Message 8 of 8
(4,224 Views)
