how to call static VI reference
Sir , I have problem to call static VI refernce in my main Program of ODE solver.Give solution to my problem.this is example problem given in labVIEW 8 i.e.,ODE circuit.
(2,666 Views)
The Help for that function tells you what to do:
ODE F(X,t) is a strictly typed reference to the VI that implements the right-hand side of an ordinary differential equation dX/dt=F(X,t). Create this VI by starting from the VI template located in labview\vi.lib\gmath\ode.llb\ODE rhs.vit.
There are also several examples that ship with LabVIEW showing you how to use ODE Solver.
(2,636 Views)
