how to change X,Y axis in intensity graph
hello
can anyone help in solving this issue I want to change X, Y axis in intensity graph as shown in arrays?
I want the y-axis to be projected as wavelength values in1D array, X-axis to be projected as Data in fs values in a 1D array.
Note- data in the graph shouldn't change only the numbering on X, Y-axis should change
thanking in advance,
(3,721 Views)
Hi RAJ,
apply some scaling (offset/multiplier) to the axis values using property nodes…
(3,719 Views)
could you elaborate more how to do that?
the spectrum in the x axis is not equally spaced
I need to make the spectrum scale of the left graph into the intensity graph
(2,308 Views)
Hi melabd,
Then you should apply the same scaling properties as with your waveform graph.
Unfortunately you forgot to post your code (aka VI) so we cannot help you much further…
(2,303 Views)
