how to change cluster single element boolean text ..
Dear Sir,
                 i Need to change each single element boolean text in cluster  for programatially and here attached my example program it will change only lable text but i need to change boolean text of cluter element  .it posssible or not.
(3,714 Views)
Accepted by topic author GokulGKM
Your program is not attached.
All you need to do is right click on the specific element you want to change and Create Property node on that.
(3,707 Views)
Here is a KB on programmatically changing the properties of an object in a cluster.
http://digital.ni.com/public.nsf/allkb/A738F46B97A4D63386256CE8005C1E5C
If I remember correctly implicitly and explicitly linked property nodes will not change what they are referencing if you change the cluster.  If you use the third method the index might change so you may want to change how you select which item you want to change (perhaps by label.text if you do not plan on changing that).
If someone can confirm/deny my first statement that would be great
(3,702 Views)
Dear sir,
                thanks for replay.if its possible to array single element boolean text change...
(3,686 Views)
Hi mad,
I guess you want to change properties of a single button in an array of buttons: No, this is NOT possible!
In an array all elements share the same properties except their value!
(3,678 Views)
ok thanks..
(3,624 Views)
