how to change picture ring value in array based array index value programmatically
hi
Can any one tell, how to change the picture ring value of the within an array based an array index position.
I am trying to show different pictures within an array based on index programmatically.
(array index is not fixed, it changes based on UI.)
Ran
(3,218 Views)
I don't understand what you are trying to say at all.
What does the array index represent?  What are you trying to change?
(3,192 Views)
The picture index is the data of the array, so all you need to do is the following.
(3,183 Views)
