how to change slide needle size programaticaly?
I've tried to change needle size using "property node", but there is only housing size, not movavle element size. How it is done?
(2,865 Views)
Does anyone knows the answer?
(2,846 Views)
It doesn't look like you do it programmatically but you might be able do something by
David
(2,842 Views)
