how to change z axis limits programmatically
Could you show how to change z-axis limits (min and max) programmatically in the attached VI?  It is a simple VI that uses the 3D plot.  Would it be the same on x and y axes as well?  Would really appreciate your insights.  Thanks.
(3,941 Views)
Accepted by topic author scatjayy
I don't have LV 7 installed so I can't post the VI sorry.. here's the short answer to your question, you have to use property and method nodes from the ActiveX palette (see screen shot), item 0 is scale X, item 1 is scale Y and item 2 is scale Z.
More generally there are loads of threads dedicated to 3D graph issues, just do a forum search ;).
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,923 Views)
By the way, I was sure there was a 3D Graph thread that regroups all the 3D grapg related topics (like there is the Excel Board) but I couldn't find it, is it my memory that is corrupted?
Epictetus
Antoine Chalons
(3,917 Views)
THANK YOU!Smiley Happy
(3,884 Views)
